• 19.11.2026, 07:19
yvelt
ATI R9 290x Connection terminal for SLI/CROSSFIRE using Backplates with Active XCS
mercredi 7 octobre 2015, 20:00
Hi there
i'm new to the forum and to AquaComputer... i could not find a help line in English on the site hence i'm in this forum...
Could anyone tell me if there's a Connection Terminal Block for multiple cards (4 (23551) or 5 (23552) slots) with the additional slot for the Backplate with Active XCS (23587) cooling heatpiep to go into the water channels?
Is it possible to order a multiple card Connection Terminal that can work with 2 Backplate with Active XCS for my double ATI R9 290X cards?
Thanks
jeudi 8 octobre 2015, 01:20
These two Kryoconnect Kits are active back plate compatible for either 3 or 4 slot separation.
yvelt
jeudi 8 octobre 2015, 13:58
oh cool thanks for the link :)
oh man issue is most of the 16x dual mother boards are 5 slots apart... older ones are 4 slots...
any chance they make a 5 slot connection block that works with ;) Active cooling back plate
jeudi 8 octobre 2015, 15:53
Those two were all I saw in their shop.
Shoot an email to customer service at support@aqua-computer.de to see what their plans are.
jeudi 8 octobre 2015, 15:58
We have no other adapters nor will we produce one.
yvelt
vendredi 9 octobre 2015, 14:58
oh darn, so for the 5 slots apart configuration with active cooling backplates, i will have to have a physical tube connecting both terminals? or run them individually to 2 separate radiators?
vendredi 9 octobre 2015, 15:57
If neither of those 2 bridges fit, then yes, you will have to manually connect them.
Which motherboard are you using?
yvelt
lundi 12 octobre 2015, 10:05
I have Asrock z77 Extreme 9 for a small upgrade to 3.0 with dual 16x rails (this is a 5 rails apart between both cards same as for the Asus P8Z77-V_Premium)
my older Asrock Z68 extreme 7 gen 3 only has 2.0 dual 16x rails *ivy 3770K just makes one rail 3.0. however this is a 4 rails apart between both cards.
lundi 12 octobre 2015, 11:07
Best I can tell looking at the manual, for 2 card SLI, this mobo says use slots 1 & 5, which has 3 unused slots between, and the longest kryoconnect kit has 2 unused slots between.
So, yes, you will need to interconnect the two GPU cards manually, which is not hard to do, and the look can be made to match the rest of your loop.
yvelt
lundi 12 octobre 2015, 12:36
is there any Aquacomputer dealer in Singapore?
mardi 13 octobre 2015, 05:05
Not sure if you are looking for a brick & mortar store or if online will do, but Performanse-PCs has Singapore in their country list for shipping, so they may be an option.
mardi 13 octobre 2015, 09:16
We also ship to Singapore ;)
yvelt
mercredi 14 octobre 2015, 02:04
just noticed a big price increase/revision on the website? now it's cheaper to get from the US sites instead
mercredi 14 octobre 2015, 14:14
Prices have not changed at all since a very long time.
yvelt
Fitting clearance on the Cupliex Kryos HF for socket 1155/1151 ... can it take 19/13 fittings and tubes?
jeudi 15 octobre 2015, 08:20
quick question about the CPU cooler
cuplex kryos HF for Socket 1366/1156/1155/1151/1150/775, G1/4
79,90 EUR
Can it take 19/13mm tubing fittings? or are the exit ports too near each other?
yvelt
jeudi 15 octobre 2015, 08:23
oh by i was checking out prices just last weekend and it all seemed to have jumped by15-20% in EUR? example the backpack was around 33.60 when i copied onto my list and later now it's 39.90
yvelt
Does a Radical 2/280 radiator with copper fin exist?
dimanche 18 octobre 2015, 14:48
does aquacomputer make a Radical 2/280 radiator with copper fin? can't seem to find it
mardi 20 octobre 2015, 12:12
The threads of the cupley kryos have a center to center distance of 23.75mm. Unlikely that this will work with fittings for 19mm tubes because I assume the fittings will be even larger than the tubing itself.
I assume the first time you were logged in with your correct address details so the VAT (19%) has been already removed. As said, we have not changed any prices lately.
The airplex radical 2/280 is not availavle with copper fins.
yvelt
mercredi 4 novembre 2015, 14:16
any one know where to get Ramplex instructions in English? the 2 sets i ordered came with instructions in German only...
mercredi 4 novembre 2015, 14:59
There is no English manual available for it. You can copy/paste the text from German PDF to translate it with Google for example.
