• 27.09.2026, 20:46
Log Data save
lundi 4 janvier 2016, 21:58
I know the Overview pages can be saved, and since the last aquasuite update the aquaero profiles can be saved, but are the aquasuite Data log settings saved anywhere? If so, where, so that I may back it up
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (4 janvier 2016, 21:59)
Railgun
mercredi 6 janvier 2016, 11:19
I poked around a bit and couldn't find anything relevant. I assumed you did the same.
Perhaps its saved with the profile itself? Only way to see is to wipe and re-import a saved profile...assuming you've not done that already.
GTXJackBauer
mercredi 6 janvier 2016, 11:51
I think you need to go to Data Log, Automatic Data Exports and ADD a saved location if you haven't.
mercredi 6 janvier 2016, 13:11
Sleuthing around a bit more, it looks like the Data Log Setting and Analyze Data chart information is held in C:\ProgramData\aquasuite-data\aquasuite_db.database.
At least I see the Data Log title and the Analyze Data saved chart names in the database.
I believe that function is for exporting data, not saving the setups.
GTXJackBauer
mercredi 6 janvier 2016, 13:59
Oh. Yeah, saving the configuration is under systems and than settings and profiles.
Exporting in the software is another term for save as.
