• 29.11.2026, 09:34
Enser
Farbwerk only outputting red
mercredi 6 janvier 2016, 23:44
As the subject says, my Farbwerk controller is the non-bt version. Have tried multiple outputs with different Aquacomputer RGB cables and multiple strips and no luck- only getting dim red every time. Using Aquasuite 2015 v9 and its showing up fine with full color wheel in Aquasuite.
Advice would be appreciated.
GTXJackBauer
RE: Farbwerk only outputting red
jeudi 7 janvier 2016, 07:08
Make sure the teeth from your LED cables are piercing in the right place of the LED strips and that the cable is connected correctly to the Farbwerk.
JasonMorris
jeudi 7 janvier 2016, 14:47
I had this and it was down to the contacts not being aligned. Pull it and reseat it.
Enser
vendredi 8 janvier 2016, 21:51
Will take it out and debug, thanks for the advice!
