• 30.09.2026, 08:29
nightlust
Aquaero 5/6 LCDHype Scripts
lundi 11 janvier 2016, 04:17
You will need to have the USB Page added to your Aquaero in order for this to work properly.
You will also need to download a copy of LCDHype: Download Here!
WinAMP:
You will need: Plugins
Place the WinAMP plugin in the WinAMP plugins directory.
Enable the Winamp Data Collector Plugin Visualization
Place the Aquero LCDHype plugin in the LCDHype plugins directory.
Code source
1
2
3
4
5
6
7
8
9
10
11
12
13
14
ID=//ScreenDefTitle=WinAMP info with VUSpecCharFile=#Header
%Common.SetPriority(200)%LCD.Gfx_SetTextArea(0,0,256,64)
#EndHeader#GfxMode
%LCD.Gfx_SetOverlayMode()%If(%WinAmp.Status() = -1) Then {%Common.ChangeScreen(0,3)}/SpecAnalyzer/%WinAmp.SpecAnalyzer(FFT, PeakedBars, 64, 25, 5, 9, 2, 1, 1, 110, 15)
/TrackNo/%Common.CreateNewLine()%LCD.Gfx_SetFont('Copperplate Gothic Light',10,1,0)%Format.Offset(Horizontal, 5) %Format.Offset(Vertical,-14)%Inc(%WinAmp.TrackNo(),1)''%WinAmp.Coun­tTracks()
/RawTitle/%Common.CreateNewLine()%LCD.Gfx_SetFont('Copperplate Gothic Bold',10,1,Bold)%Format.Offset(Horizontal,30)%Format.Offset(Vertical,-16)%Param.EnableScrolling(Horizontal,Swing,­1,235,1)%WinAmp.RawTitle()
/TrackPos/%LCD.Gfx_SetFont('Copperplate Gothic Light',6,1,0)%Common.CreateNewLine()%Format.Offset(Horizontal,5)%Format.Offset(Vertical,14)%Format.Time(%Mul(%WinAmp.TrackPos(),1000),'mm:ss')''/TrackLength/%Common.CreateNewLine()%LCD.Gfx_SetFont('Copperplate Gothic Light',6,1,0)%Format.Offset(Horizontal,57)%Format.Offset(Vertical,-10)%Format.Time(%Mul(%WinAmp.TrackLength(),1000),'mm:ss')
/StatusBar/%Format.Bar(Horizontal,235,2,0,%WinAmp.TrackLength(),%WinAmp.TrackPos(),1,0,11,3­2)
/Playlist next 3 title/
%Common.CreateNewLine()%LCD.Gfx_SetFont('Copperplate Gothic Light',6,1,Bold)%Format.Offset(Horizontal,5)%Format.Offset(Vertical,3)%Param.EnableScrolling(Horizontal,Swing,­1,235,1)%WinAmp.RawTitle(%Inc(%WinAmp.TrackNo(), 1))
%Common.CreateNewLine()%LCD.Gfx_SetFont('Arial',6,1,Bold)%Format.Offset(Horizontal,5)%Format.Offset(Vertical,-2)%Param.EnableScrolling(Horizontal,Swing,­1,235,1)%WinAmp.RawTitle(%Inc(%WinAmp.TrackNo(), 2))
%Common.CreateNewLine()%LCD.Gfx_SetFont('Arial',6,1,Bold)%Format.Offset(Horizontal,5)%Format.Offset(Vertical,-2)%Param.EnableScrolling(Horizontal,Swing,­1,235,1)%WinAmp.RawTitle(%Inc(%WinAmp.TrackNo(), 3))
#EndGfxMode
//EndDef
5.1 VU Meter:
You will need: LCDHype Plugins
Place the Aquero LCDHype plugin in the LCDHype plugins directory.Place the VU meter plugin in the LCDHype plugins directory.
Code source
1
2
3
4
ID=//ScreenDefTitle=System SoundSpecCharFile=#Header%Graph.SetTextArea(0,0,256,64)%Graph.SetRefreshArea(0, 0, 256, 64)%Param.RenderMode(Full)%Common.SetPriority(200)%Graph.SetPixel(12,3,1)%Graph.SetPixel(12,4,1)%Graph.SetPixel(12,5,1)%Graph.SetPixel(12,6,1)%Graph.SetPixel(13,3,1)%Graph.SetPixel(13,6,1)%Graph.SetPixel(14,2,1)%Graph.SetPixel(14,7,1)%Graph.SetPixel(15,1,1)%Graph.SetPixel(15,2,1)%Graph.SetPixel(15,3,1)%Graph.SetPixel(15,4,1)%Graph.SetPixel(15,5,1)%Graph.SetPixel(15,6,1)%Graph.SetPixel(15,7,1)%Graph.SetPixel(15,8,1)#EndHeader
#GfxMode
%If( %System.Input(GetCode) = 8 )Then { %Common.ChangeScreen(0,Next) }%Graph.Font('Lucida Console', 5, 1)%Format.Bar(Vertical, 10, 61, 0, 550000, %Plugin.VolumePeakmeter.GetPeakChannel(1), 1, 0, 0, 1)/Left/%Format.Bar(Vertical, 10, 61, 0, 550000, %Plugin.VolumePeakmeter.GetPeakChannel(2), 1, 0, 244, 1)/Right//%Format.Bar(Horizontal, 150, 5, 0, 50, %Plugin.VolumePeakmeter.GetVolumeStepInfo('Step'), 1, 0, 5, 37)//VolumeStep (51 Steps on my RTL Sound Chip)/%Format.Bar(Horizontal, 52, 6, 0, 1000000, %Plugin.VolumePeakmeter.GetVolumeMasterLevelScalar(), 1, 0, 18, 2)/VolumeLevelScalar/%Format.Bar(Horizontal, 70, 5, 0, 550000, %Plugin.VolumePeakmeter.GetPeakChannel(5), 1, 0, 14, 58)/BackLeft/%Format.Bar(Horizontal, 70, 5, 0, 550000, %Plugin.VolumePeakmeter.GetPeakChannel(6), 1, 0, 170, 58)/BackRight/%Format.Bar(Horizontal, 70, 5, 0, 550000, %Plugin.VolumePeakmeter.GetPeakChannel(3), 1, 0, 92, 1)/Center/%Format.Bar(Horizontal, 70, 5, 0, 550000, %Plugin.VolumePeakmeter.GetPeakChannel(4), 1, 0, 92, 58)/Sub/%Common.CreateNewLine(1,72,2)%Round(%Div(%Plugin.VolumePeakmeter.GetVolumeMasterLevelScalar(),10000))'%'%Common.CreateNewLine(1,22,10)'dB '%Trunc(%Div(%Plugin.VolumePeakmeter.GetVolumeMasterLevel(),1000000),4)%Common.CreateNewLine(1,90,18)%Graph.Font('Cambria', 7, 1)'Sound Blaster ZxR'%Common.CreateNewLine(1,76,28)%Graph.Font('Brush Script MT', 9, 1,)'DTS-HD 5.1 Surround'%Common.CreateNewLine(1,184,12)%Graph.Font('Stencil', 9, 1,)'THX'%Graph.Font('Lucida Console', 5, 1)%Common.CreateNewLine(1,12,30)'Left'%Common.CreateNewLine(1,220,30)'Right'%Common.CreateNewLine(1,30,50)'Rear Left'%Common.CreateNewLine(1,184,50)'Rear Right'%Common.CreateNewLine(1,114,9)'Center'%Common.CreateNewLine(1,108,50)'Subwoofer'%Common.CreateNewLine(1,210,10)/'CPU '%System.CPU(Usage)' %'/%Common.CreateNewLine(1,202,1)%System.GetDateTime('mm/dd/yyyy')%If( %Plugin.VolumePeakmeter.GetMute() = 1 ) Then{%Graph.SetPixel(197,2,1)%Graph.SetPixel(196,3,1)%Graph.SetPixel(194,4,1)%Graph.SetPixel(193,5,1)%Graph.SetPixel(191,6,1)%Graph.SetPixel(190,7,1)} Else{%Graph.SetPixel(197,2,0)%Graph.SetPixel(196,3,0)%Graph.SetPixel(194,4,0)%Graph.SetPixel(193,5,0)%Graph.SetPixel(191,6,0)%Graph.SetPixel(190,7,0)}#EndGfxMode
//EndDef
AC3 Style VU Meter:
Code source
1
2
3
4
ID=//ScreenDefTitle=AC3 StyleSpecCharFile=#Header%Graph.SetTextArea(0,0,256,64)%Graph.SetRefreshArea(0, 0, 256, 64)%Param.RenderMode(Full)%Common.SetPriority(100)%Graph.SetPixel(92,3,1)%Graph.SetPixel(92,4,1)%Graph.SetPixel(92,5,1)%Graph.SetPixel(92,6,1)%Graph.SetPixel(93,3,1)%Graph.SetPixel(93,6,1)%Graph.SetPixel(94,2,1)%Graph.SetPixel(94,7,1)%Graph.SetPixel(95,1,1)%Graph.SetPixel(95,2,1)%Graph.SetPixel(95,3,1)%Graph.SetPixel(95,4,1)%Graph.SetPixel(95,5,1)%Graph.SetPixel(95,6,1)%Graph.SetPixel(95,7,1)%Graph.SetPixel(95,8,1)#EndHeader
#GfxMode
%If( %System.Input(GetCode) = 8 )Then { %Common.ChangeScreen(0,Next) }%Graph.Font('Lucida Console', 5, 1)%Format.Bar(Vertical, 10, 51, 0, 500000, %Plugin.VolumePeakmeter.GetPeakChannel(1), 1, 0, 0, 1)/Left/%Format.Bar(Vertical, 10, 51, 0, 500000, %Plugin.VolumePeakmeter.GetPeakChannel(2), 1, 0, 10, 1)/Right//%Format.Bar(Vertical, 150, 5, 0, 50, %Plugin.VolumePeakmeter.GetVolumeStepInfo('Step'), 1, 0, 5, 37)//VolumeStep (51 Steps on my RTL Sound Chip)/%Format.Bar(Horizontal, 52, 6, 0, 1000000, %Plugin.VolumePeakmeter.GetVolumeMasterLevelScalar(), 1, 0, 100, 2)/VolumeLevelScalar/%Format.Bar(Vertical, 10, 51, 0, 500000, %Plugin.VolumePeakmeter.GetPeakChannel(5), 1, 0, 20, 1)/BackLeft/%Format.Bar(Vertical, 10, 51, 0, 500000, %Plugin.VolumePeakmeter.GetPeakChannel(6), 1, 0, 30, 1)/BackRight/%Format.Bar(Vertical, 10, 51, 0, 500000, %Plugin.VolumePeakmeter.GetPeakChannel(3), 1, 0, 40, 1)/Center/%Format.Bar(Vertical, 10, 51, 0, 500000, %Plugin.VolumePeakmeter.GetPeakChannel(4), 1, 0, 50, 1)/Sub/%Common.CreateNewLine(1,154,2)%Round(%Div(%Plugin.VolumePeakmeter.GetVolumeMasterLevelScalar(),10000))' %'%Common.CreateNewLine(1,104,10)'dB '%Trunc(%Div(%Plugin.VolumePeakmeter.GetVolumeMasterLevel(),1000000),4)%Common.CreateNewLine(1,88,28)%Graph.Font('Brush Script MT', 9, 1,)'DTS-HD 5.1 Surround'%Common.CreateNewLine(1,228,52)%Graph.Font('Stencil', 9, 1,)'THX'%Graph.Font('Lucida Console', 5, 1)%Common.CreateNewLine(1,2,54)'L'%Common.CreateNewLine(1,12,54)'R'%Common.CreateNewLine(1,21,54)'RL'%Common.CreateNewLine(1,31,54)'RR'%Common.CreateNewLine(1,42,54)'C'%Common.CreateNewLine(1,50,54)'SW'%Common.CreateNewLine(1,210,10)/'CPU '%System.CPU(Usage)' %'/%Common.CreateNewLine(1,212,1)%System.GetDateTime('mm/dd/yyyy')%If( %Plugin.VolumePeakmeter.GetMute() = 1 ) Then{%Graph.SetPixel(197,2,1)%Graph.SetPixel(196,3,1)%Graph.SetPixel(194,4,1)%Graph.SetPixel(193,5,1)%Graph.SetPixel(191,6,1)%Graph.SetPixel(190,7,1)} Else{%Graph.SetPixel(197,2,0)%Graph.SetPixel(196,3,0)%Graph.SetPixel(194,4,0)%Graph.SetPixel(193,5,0)%Graph.SetPixel(191,6,0)%Graph.SetPixel(190,7,0)}#EndGfxMode
//EndDef
Enjoy!!!
Ce message a été modifié 9 fois. Dernière modification effectuée par "nightlust" (13 janvier 2016, 01:43)
Nightlust
GTXJackBauer
lundi 11 janvier 2016, 13:26
Wow, thank you for this. Could you possibly show us in images as well. That would be greatly appreciated.
nightlust
lundi 11 janvier 2016, 15:06
Here is the Surround VU Meter:
I will post the other 2 when I get home tonight!
Ce message a été modifié 1 fois. Dernière modification effectuée par "nightlust" (11 janvier 2016, 15:07)
Nightlust
nightlust
mardi 12 janvier 2016, 22:45
Screenshots added. (Post edited.)
Ce message a été modifié 1 fois. Dernière modification effectuée par "nightlust" (12 janvier 2016, 22:46)
Nightlust
