• 05.10.2026, 14:13
k2mit
Leak/water sensor and Aquearo
vendredi 5 février 2016, 06:13
Can you connect a 2-pin water sensor to the Aquero and have Aquasuite raise an alarm on closed contact? I would have thought this would be a sensor from Aqua Computer but a search on these forums doesn't mention anyone using Aquero for leak sensor. I want to get rid of my Koolance 3-sensor leak detector ideally.
Thank you.
vendredi 5 février 2016, 13:50
Would only work if your sensor shorts or opens the two pin connection of a temperature sensor port. In this case you would add a 10kOhm resistor to the line so you get a fake temperature of about 25°C which will be uses as base value and will not trigger an alarm. As soon as the signal becomes invalid (shorted or open) it will trigger the alarm.
k2mit
vendredi 5 février 2016, 18:52
Ok thanks. That makes sense.
On a related topic, I am using all flat-black fittings and the AQ in-line G1/4 water temp fitting is not. Are other company's in-line water temp sensors "plug and play" with aquaero or do I have to use only yours. I guess I can tuck it out of the way.
Suggestions to product management: many vendors are moving in the direction of 4-5 colors for every fitting. They look great; not sure if they all sell well though.
Thank you for the continued advice.
lundi 8 février 2016, 12:24
Other temperature sensors must use a 10kOhm NTC to be compatible.
Discussions similaires
