• 10.10.2026, 03:04
Understanding the "aquajet rinsing device for aquatube G1/4"
lundi 22 février 2016, 03:09
Am I correct in assuming that the "aquajet rinsing device for aquatube G1/4" is best installed in the center bottom port of the "aquatube G1/4", with the loop's return line then attaching to the bottom of the rinsing device and forcing the returning water to wash over the circular acrylic plate?
lundi 22 février 2016, 15:10
Correct.
lundi 22 février 2016, 16:43
Thank you Shoggy, a couple more questions if I may;
With the aquatube in a vertical orientation and the return line connected to the rinsing device, will it be best to use a bottom port, or the lower side port as the suction to minimize the possibility of cyclonic activity, .
I would also like to use a Pressure sensor mps pressure Delta 40.
Would it be possible to order an Acrylic glass cover for aquatube and have aquacomputer tap a G1/4 port into it for installation of the required Pressure equalization membrane?
jeudi 25 février 2016, 20:52
May have use for an aquatube in my next build.
I think using the lower side port would be best for suction as it may tend to destroy any cyclonic rotation that tries to build.
Another shot with rinsing device, and one sans rinsing device. With looks much better.
