• 18.11.2026, 03:31
bishop149
Aquaero 6 Pro + High Flow USB Flow sensor
mercredi 24 février 2016, 00:13
I'm having some trouble understanding how to wire up these two up in the most efficient manner.
The manual for the high flow sensor states that I should connect it to a USB header on the motherboard
The Aquareo manual however states that the Aquabus connection can also transfer power when the forth pin is used.
If I connect the Flow Sensor via the aquabus using the a 4-pin connection do I still need to wire up the USB header?
If so I think this would be the best option, rather than use up a motherboard header needlessly.
Thanks in advance for any help!
mercredi 24 février 2016, 09:58
If you use a 4-pin aquabus cable, you will not need the USB cable in addition. It is only required if you use a 3-pin aquabus cable because this one can not forward power from the aquaero to the sensor.
