• 10.10.2026, 16:14
Crossflow
Motherboards and waterblocks compatible with Spacer for Intel Skylake CPUs?
vendredi 4 mars 2016, 11:39
Hi all,
there is someone who mount bare die 6700K with this spacer?
I have asus maximus VIII gene motherboard, how can I understand if it is compatible?
Do I have to completely remove retention system (backplate included)?
If my waterblock contact surface area is too large, how to proceed?
cut the socket corners or modify waterblock?
Thanks!
mercredi 9 mars 2016, 11:27
The problem are the corners of the socket. They are slightly higher than the CPU die.
You will need a block that uses a surface that does not cover these corners (we have none); or you have to modify the block for this area of you have to grind down the plastic of the socket in the corners.
Discussions similaires
