• 22.11.2026, 10:58
YahgRaider
Aquaero 6 XT screen cover falling off
lundi 7 mars 2016, 12:59
Hi all,
I have a slight problem with my Aquaero 6 XT, the clear plastic cover over the screen, the piece the fits within the metal outer plate, keeps falling off. looks like it was stuck on with some form of glue before, i am wondering how best to fix this. What sort of glue was used before and how do i stick it back on without affecting how the touch buttons function?
Thanks
Ollie
lundi 7 mars 2016, 19:42
That is a known issue and your best path to resolution is to contact support@aqua-computer.de
YahgRaider
lundi 7 mars 2016, 21:06
Ah ok, will do that.
Thanks
