• 22.11.2026, 20:56
meezits
D5 pump
samedi 12 mars 2016, 19:51
Hello! :D
I've used a d5 pump before but it had a compression thread to tighten to the reservoir.
On my aqualis base, the d5 just is held in place with screws and a aluminium plate.
What worries me in the d5 pump just moves free inside (spins very easily) and I feel like that's not correct. If there suppose to be a gasket that's tight?
Thanks a lot everyone!
Kyle
lundi 14 mars 2016, 10:40
Did you install the O-ring between the pump and the pump-top?
I can see where the pump would spin if you do not have the O-ring seated in place.
meezits
lundi 14 mars 2016, 15:06
I thought someone might say that :/, I didn't get an gasket, nor did I even get screws in the box to clamp the ring down. I had to buy m4x12mm somewhere local.
