• 22.11.2026, 20:58
YmirNOR
Help with Airplex GIGANT 1680 setup
lundi 4 avril 2016, 10:47
When the pump my old trusted aquaduct 360 XT mark III stopped working I decided to upgrade to the Airplex Gigant.
Started to set it up this weekend with D5 pump and reservoir in the top, but I have one thing I would like to verify and that is how the internal and outer port are linked up.
Do the left outer correspond to the left inner port? So if I close of the left outer port it is the left inner I should use?
I have tried to search for this online but there is little information in the Gigant online.
This is how I plan set up my loop:
Pump > CPU > GPU > IN, left outer port on Gigant / OUT, right inner port (the one closet to the center) > reservoir
Would be a bit embarrassing if I set it up so the flow does not flow through the radiators, but straight trough :wacko:
Thanks in advance for any tips.
lundi 4 avril 2016, 13:48
The Gigant comes with a G1/4, headless screw that needs to be inserted into the inlet port.
I had the same question, and Shoggy sent me the diagram below.
Here is a shot of my connections...
and a link to my mini-build-log can be found here.
I also STRONGLY recommend you add some rubber bumpers to the bottom of the feet, or they will destroy your desktop. THIS is what I used.
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (4 avril 2016, 13:54)
YmirNOR
lundi 4 avril 2016, 14:44
Thank you very much InfoSeeker!
This was just what I was looking for :thumbsup:
Hm, I cant remember finding the headless screw with the parts I got.
Shoggy, can this part be found on the shop so I can order it?
Thx in advance.
lundi 4 avril 2016, 22:40
It is available in the shop but should have come with the radiator. If that was not the case you should send us an e-mail with your address.
