• 29.11.2026, 02:59
barfly
aida 64 issue
vendredi 6 mai 2016, 17:58
im using aquasuite software with aida software and upon starting things up within a few minutes my aida sensors quit being read by aaquasuite
sometimes aquasuite will eventually reset and begin working again but sometimes not
any ideas?
tia
RE: aida 64 issue
vendredi 6 mai 2016, 21:42
any ideas?
tia
Is AIDA64 using Shared Memory or WMI to communicate with aquasuite?
Might try swapping between the two, to see if that helps..
barfly
samedi 7 mai 2016, 00:16
both of those are checked and swapping them to and fro crashes aida64
samedi 7 mai 2016, 16:02
mhmm... I swapped between WMI & Shared Memory in AIDA64 without crashing issues.
If you have both activated, the only thing I can think off is to deactivate one and see if that helps.
Personally, I prefer Shared Memory because I believe it to be faster than writing to, and reading from disk.
Do you have a Corsair AX---i PSU with CorsairLink installed?
barfly
dimanche 8 mai 2016, 21:25
no corsair link,no aisuite or fan controllers
deselecting either WMI or Shared Memory crashes aida64.
lundi 9 mai 2016, 07:45
WMI is also located in RAM. But WMI needs significant more cpu performance than Shared Memory.
lundi 9 mai 2016, 13:43
Thank you for the clarification Sebastian... greatly appreciated.
barfly
lundi 9 mai 2016, 17:43
i have a 5930k w/32 gig memory,neither should be an issue.
mardi 10 mai 2016, 00:34
Perhaps to try uninstall/reinstall AIDA64?
Or install HWiNFO and see if you have the same result?
barfly
mardi 10 mai 2016, 04:47
i have used hwinfo without any issues,i also should point out i also have a 4930k w/32 gig ram with the exact issues,
Lazran
mercredi 11 mai 2016, 20:08
I had trouble with Aida64 as well. Switched over to HWinfo64 and have been problem free ever since. Plus HWinfo64 is free :)
GTXJackBauer
jeudi 12 mai 2016, 01:52
+1 Same here.
