• 12.10.2026, 19:22
psychotik2k3
Can i use Aquaero 5 pwm plug 1 or 2 to power a small fan ? (to cool fan controllers)
dimanche 22 mai 2016, 14:12
I'm making my own case and the aquaero and fabwerk are both i a acrylic box,
the problem is taht when operating the fan controller temperatures are rising agin and again...
now they are at 39.3 celsius degres.
I have a small fan 6cm diameter with 2 pins i salvage from my former seasonic PSU, and i wonder if i can plug it to the pwm plug (1 or 2) as it got 2 wires and the written current is 0.13Amp for 12V
it should work isn't it ???
i cannot plug it to other Fan header as they are all 4 used: 3 fan channels and 1 pwm for controlling my pump.
oh and by the way what is a good temperature range for the fan controllers ??? (to setup the aquaero)
thanks
lundi 23 mai 2016, 13:58
It should work but the 2-pin PWM channels work with a pulsed 12V signal and not a regulated voltage. Some fans do not like this way of voltage supply and may start to generate a humming noise. If this does not matter you will have nothing to worry ;)
Discussions similaires
