• 09.10.2026, 20:09
egocentrik
AC Watercooling in CM Stacker :)
vendredi 6 août 2004, 00:01
Hi Guys,
I come across this site and became fond of the products offered here :D
I'm from Belgium and do not spead much german; "Ober einen bier", "wiefiel bitte?" are the most of my german language ;D So sorry but all will be in english 8)
Thanks to Stefan kindness (from aquacomputer.de), with him I have been able to acquire a nice watercooling kit (i'm still eager to upgrade it, savings are growing ;) ;) ) .
As I promised, here are the pictures of my newly build computer with this nice wc kit.
The tower alone:
[img]http://nycz.us/is.php?i=14490&img=fotob.jpg[/img]
Reversed design: Radiators are down (the air is still sucked outside the computer)
[img]http://nycz.us/is.php?i=14491&img=fotoe.jpg[/img]
Fortunately the airflow is not hindered because "the thing" is on its toes. Wheels provided by CM :)
[img]http://nycz.us/is.php?i=14500&img=fotor.jpg[/img]
Aquastream controller
[img]http://nycz.us/is.php?i=14498&img=fotoi.jpg[/img]
Aquatube in Aquabay (reverse view)
[img]http://nycz.us/is.php?i=14497&img=fotog.jpg[/img]
Aquatube in Aquabay (front view)
[img]http://nycz.us/is.php?i=14495&img=fotof.jpg[/img]
The thing has been filled up - now some glowmotion fluid.
[img]http://nycz.us/is.php?i=14492&img=fotoo.jpg[/img]
I remarked some problem was growing up with the pressure inside the tubes. >:(
Ok I emptied the circuit and devised another tube routing ;)
The thing is fed again, no more problems ;D
[img]http://nycz.us/is.php?i=14493&img=fotoq.jpg[/img]
The result: :)
[img]http://nycz.us/is.php?i=14494&img=fotos.jpg[/img]
The next steps will be:
-chipset wc :)
-vga wc. Not the one on the pics (my old Hercules 3D prophet Radeon 9700) but a new ASUS V9999GE (Nvidia 6800 based) ;D
-some t° mesuring & fan control :)
I'll be happy to have comments & Remarks from more experienced watercool-guys : :) :) :)
Greetings Alain
FreezedComputer
Re: AC Watercooling in CM Stacker :)
vendredi 6 août 2004, 00:09
let the fans blow the air into the case(heat goes up...)
-sweet-
vendredi 6 août 2004, 02:25
why don't you use any angles? i don't like these big curves
AMD Athlon XP 1700+ @ 2400Mhz ( DLT3C T-Bred B JIUHB 03010 WPMW ) cooled by cuplex Epox 8RDA3+ cooled by twinplex Inno3D Personal Cinema FX 5900 cooled by twinplex System @ Nethands
sikzorro
vendredi 6 août 2004, 11:49
Sh.., i had the same idea with the radiator at the bottom of the case.
Now i have to think about it ;D
SiKZorro
Dr.Lecter
vendredi 6 août 2004, 12:29
hi
i found the case nice.what´s the name of it and were can i buy it???
Stefan_K.
vendredi 6 août 2004, 13:26
Hi Alain,
nice work. Hope you are lucky with the watercooling kit.
Cheers
Stefan
powerslide
vendredi 6 août 2004, 14:36
oh i really like radiators at the bottom ..
but i decided to make it external for a nearly passiv cooling possibility ..
if it's to hot the rear fan sucks the warm air out of the case through a evo120
some pics:
selfmade external mounting
stealth aquastream controller
greetz
slide
egocentrik
vendredi 6 août 2004, 20:44
Hi all,
Thank for the replies
@ _Nobody_
Next time I do an upgrade, I will give a try reversing the airflow. ;) I just fear the air inside will go hotter, I only use a passive GPU heatsink which spread much heat inside. With D3 the air inside my case begins to heat up. Under stress conditions (D3) the Case temp is 45-50°C & the Cpu temp is 50 °C. Before WC, & without o'clocking my old PIV 2.53 I reached cpu temp of 72°C. Idle the case is near 38-40°C & The CPU is 46°C
Btw now my CPU is a Prescott 3.2 @ 3.4, it is not much but with higher speeds I get problems :'( (this is not to be debated here I think) ;)
@ -sweet-
Matter of taste I think. With short (rigid) tubes using angles don't you get problems when you need to move something ?
Remember, this is my first experience in wc & case modding. 8)
@<SIK>Zorro
It works fine :), Maybe just the airflow question is still to be tested. (in through the case or out against the natural tendency of warm air to go upside) :)
@DrLecter
The case i have is the CM stacker stc-01 from CoolerMaster
http://www.coolermaster.com/special_repo…t01/stc-t01.htm
(around 160€ without PSU)
You should easily find a dealer in Germany or on the internet using google 8)
@Stefan K. @ apmod 90 %
Thank you :) All went very fine (exept the small, easily resolved, tube problem)
@powerslide
Nice design too ;D I hope you also enjoy much this nice case :)
Don't you fear for your external radiator & the external tubing when you move your computer (e.g: for a lan party) :-[
Thank you for the commentars
Cu all ;)
powerslide
vendredi 6 août 2004, 21:04
no i don't fear about my external components.. i just was at a lanparty last weekend and nothing happend..
i'm very carfully with my babe :)
FragMaster.nsn
vendredi 6 août 2004, 23:30
If you let the fans blow into the case you have to clean out the dust every few days, so i would let them suck through the radiator to the bottom. An airplex which is filled with dust, hairs and things like that won't work.
The warm air can not get up, if the two fans are in use.
