• 22.11.2026, 17:29
ziza
Aquaero 6XT + D5 Pump Setup
mardi 7 juin 2016, 16:44
Hello All,
I really would appreciate your assistance in the setup of my new Aquaero 6.
I have purchased my first Aquaero, and I would like to connect it to my XSPC D5 pump.
However, from the specifications, I am unable to understand what is it needed.
1) Therefore, do I need a poweradjust to connect my pump to the aquaero?
2) Since the pump is not aquacomputer, is it possible to configure rpm in aquaero or not? If so what hardware is needed?
3) I have read that Aqua Computer D5 pump motor with USB and aquabus allows to control rpm and define alarms in aquaero. Is it possible to make the same setup with XSPC pump?
4) Aqua Computer D5 pump motor with USB and aquabus interface allows to define alarms based on system's temperature and rpm. How does this works?
5) In case a D5 is required, I believe a D5 Top would be required to connect the connectors. Any recommendations?
Thank you in advance for your assistance on this regards, appreciated your inputs on above questions.
Best regards,
ziza
RE: Aquaero 6XT + D5 Pump Setup
mercredi 8 juin 2016, 13:02
Hello All,
Best regards,
ziza
Which XSPC D5 pump do you have, Vario or PWM?
ziza
mardi 14 juin 2016, 19:59
Hello,
Thank for comming back on this subject.
I have a PWM XSPC pump.
Best regards,
ziza
lundi 20 juin 2016, 14:13
If you want to control this pump via PWM you would have to modify it since it does not comply with Intels PWM standard. You can find a guide here.
Just in case you do the modification you can take the power directly from the PSU and only connect the rpm and PWM line to one of the four fan ports of the aquaero. In the fan tab you have to switch the control mode to PWM.
If you do not want to modify the pump you can only control it by its voltage. In this case you will need this adapter if the pump uses a 4-pin plug for the power and another 3-pin plug for rpm/PWM.
Discussions similaires
