• 10.10.2026, 01:16
AE5probigNGslave
Aqua Computer D5 pump motor with PWM input and speed signal - transfer rpm to flow
samedi 2 juillet 2016, 13:52
Hello All,
Is there any way in aquasuite 2016-4 to transfer rpm of this pump to flow (approximately - virtually). I have Aquaero 5 pro, Aquaero 5 lt and this pump.
Thank you in advance for answer.
dimanche 3 juillet 2016, 17:27
I don't believe so. The flow rate is dependent on the loop as much as the pump.
You will have to add a flow sensor if you wish to know the flow rate in your loop.
AE5probigNGslave
lundi 4 juillet 2016, 20:44
I thought so. Maybe it will react even Sebastian.
Thank you.
mardi 5 juillet 2016, 07:09
You can connect the rpm signgal to the flow connector and you have a flow signal.
But this makes absolutely no sense. The pump RPM has nothing to with the flow.
AE5probigNGslave
vendredi 8 juillet 2016, 20:46
Hello Sebastian,
Thank you for reply. Because I am a novice in the field of water cooling, I did not know that the resistance of the system greatly affects the final value of flow. I assumed that D5 is the macho pump.
