• 22.11.2026, 21:41
barfly
sensor issue
mardi 19 juillet 2016, 00:24
I have 6 4tb 2.5 drives in hotswap bays and using aida64 to show drive temps everything seems to function temp wise
but
when I remove these drives aquasuite still shows the drives as being monitored,meaning it shows temp functionality and changes
how is this?
Ce message a été modifié 1 fois. Dernière modification effectuée par "barfly" (19 juillet 2016, 00:36)
GTXJackBauer
RE: sensor issue
mardi 19 juillet 2016, 04:10
but
how is this?
Have you tried restarting the PC after swapping them out?
barfly
mardi 19 juillet 2016, 04:51
shouldnt have to being its a real time monitoring app,to me that makes dependability useless , but for the record i dont trust hotswaps as data can be lost if when pulling their being read so yes powering down is always done.
mardi 19 juillet 2016, 16:05
The aquasuite works with the last valid value that was provided by the monitoring program.
In the software sensor tab you could lower the timeout time and set a fallback temperature to trigger some specific action if required.
barfly
mardi 19 juillet 2016, 18:06
so with the drives removed and after a over night coldboot,the temps begin@28 and rise to @35 or so and fluctuate as the fan is keeping temps in line and this is normal?
sounds as tho only a rear power pull will remove values
mercredi 20 juillet 2016, 02:20
If the values continue to change after removing the drive, then you may not be monitoring what you think you are.
barfly
mercredi 20 juillet 2016, 02:44
that crossed my mind but these 4 drives are the only samsung drives on here so that cant be the issue.
GTXJackBauer
mercredi 20 juillet 2016, 08:26
That's what I started to think.
mercredi 20 juillet 2016, 11:23
Whatever these sensors show: the aquasuite can only process what it receives from the third party tool so this is not a problem of the aquasuite but of AIDA64 if it still provides data.
