• 01.10.2026, 07:19
MP7
Aquastream Ultimate minimum speed?
mercredi 20 juillet 2016, 20:43
Hello again forum, it's been some time... :)
That new Aquastream Ultimate pump seems really awesome but is it true the minimum speed that can be set is 3000 rpm?
Thx
jeudi 21 juillet 2016, 12:55
3000 rpm is the lowest possible speed. below this speed the pump make more noise and the vibrations.
MP7
jeudi 21 juillet 2016, 17:34
I see, I'm asking because I'm running my D5 PWM(with aquaero) on only 10% which according to aquaero spins the pump at 2100rpm, giving my loop about 96,5 l/h.
I can do more actually at 50% it's about those 3000rpm, but after that at higher speeds it gives me bubbles on the bay res.
This pump is interesting because I could remove the flow meter and even a temp sensor since the pump already has both of them inside, and judging by a review I watched yesterday noise level is pretty much the same as D5, I will give it some more thought.
Thx Seb
jeudi 21 juillet 2016, 19:57
you cant compare the speed. the aquastream has an complete different flow/pressure characteristic.
MP7
jeudi 21 juillet 2016, 20:41
Yes it crossed my mind, thought you might give some compare info, at least approximately, flow D5 at 2000rpm vs AU at 3000rpm
I'm using one of yours D5's
Discussions similaires
