• 17.11.2026, 18:01
BillLucas
Farbwerk via 4 pin aquabus.
samedi 23 juillet 2016, 18:45
Hello all, first post so be gentle.
I have my farbwerk (non Bluetooth) hooked up to my 6XT using the aquabus connectors on my real time clock module. However without a USB plug I have no control over the unit, only the ability to send it sensor information that works.
I was wondering if this is a intended feature or I'm not quite good enough on aquasuite to figure it out. I made a led controller in the 6XT controller page and assigned outputs correctly, but the controller simply doesn't respond.
Thanks for any help you can provide :)
P.S device ID 20 as suggested by AC themselves. Not conflict there
Ce message a été modifié 1 fois. Dernière modification effectuée par "BillLucas" (23 juillet 2016, 18:47)
Fieldrider
samedi 23 juillet 2016, 20:21
You need to connect the Farbwerk via USB first and then set the Input-Signal to "Aquabus". Then you should be able to let the Aquaero control the Farbwerk :)
samedi 23 juillet 2016, 21:00
To be a bit more precise: in the controller tab you have to change the mode for every channel to be controlled by an external source.
BillLucas
dimanche 24 juillet 2016, 01:32
Thanks for the assistance, in my haste to get the wiring done I unplugged the USB that I had been using, without thinking of setting changes which would have to occur first. I'll report back tomorrow and close the thread when resolved :)
Discussions similaires
