• 03.10.2026, 08:11
Beun
CoolCurrent 450 W Rev. 3 - EPS (24pins) connection
samedi 13 novembre 2004, 11:08
Does the CoolCurrent 450 W Rev. 3 - Wassergekühltes Netzteil have a EPS (24pins) connection (new P4 systems)?
x-stars
Re: CoolCurrent 450 W Rev. 3 - EPS (24pins) connec
samedi 13 novembre 2004, 11:47
The CC does have the normal 20-Pin-ATX-Connector and the 4-Pin-P4-Connector, if you really need an EPS-Connector (e.g. for Xeon-Systems) you should use an Adapter (you can buy it at pc-cooling.de or ask Stefak K. from AC-Berlin, he's always prepared for special interests ::)).
cya
x-stars
Edit: Maybe, I shoul add, that's not recommed to use ATX-NTs as EPS-NTs, becopuse in most cases you will need much power and the EPS-Standart was created to supply this power ;).
Beun
samedi 13 novembre 2004, 12:35
Thanx for the fast reply :)
I want to use it for a Asus P5AD2 Deluxe mobo (Intel 925X chipset). I prefer a watercooled PSU. So what to do...
NikoMo
NikoMod
samedi 13 novembre 2004, 12:45
hi,
we have a new board especialy for english (and english speaking) customers :)
samedi 13 novembre 2004, 13:01
This Asus-Board doesn't need the 24pin adapter. It can be used with 20/24 pin connectors. You can also buy the adapter (20>24) in our shop (but you dont need it).
Beun
samedi 13 novembre 2004, 15:30
Great to see an English section!
Thanx for all the help.
