• 18.11.2026, 01:26
Darknesse
usb connection problem of Aquero 5 lt
mercredi 19 octobre 2016, 19:21
Hello,
I just bought a Aquero 5 LT, I made all the connection correctly, but can not have access to the Aquero on Aquasuite, it strikes me that the usb connection is not good. I tested with different usb cable that works very well for instance with the powerajust 3. But nothing works he will not make the connection with the USB cable.
Yet powerajust 3 and Farbwek works very well on Aquasuite
Is the product has a defect?
sry for English I speak french
samedi 22 octobre 2016, 01:21
Just to start somewhere, you have confirmed the USB connectors are oriented properly?
Darknesse
mardi 25 octobre 2016, 17:10
Yes everything is properly connected.
Once information if it will help the red LED that confirms the connection flashes
jeudi 27 octobre 2016, 15:50
The red LED on my unit is constant red while USB is plugged in.
Perhaps best if you contact support at support@aqua-computer.de.
They may be busy for the next couple of days, it looks like something new may be be released tomorrow, so be patient :)
