• 13.10.2026, 23:31
rapapa
Dimensions Airplex Modularity
jeudi 17 novembre 2016, 21:18
Hello,
I'm considering an Airplex Modularity 140 to place at the front intake of my case. But unfortunately, I cannot find any drawing of it with the exact locations of the fan mounting holes. I need these dimensions because it will be a tight fit. Could someone supply them maybe? And I was also wondering why, although there is a 280 and 120, there is no Airplex radical 140.
Thanks in advance!
RE: Dimensions Airplex Modularity
jeudi 17 novembre 2016, 22:52
Hello,
Thanks in advance!
As to the dimensions, scroll to the bottom of Shoggy's introductory post... you will see some dimensions there.
rapapa
vendredi 18 novembre 2016, 00:21
Thank you for the reply. Unfortunately, that post only notes the outer dimensions. I need to know the location of the screw holes.
