• 22.11.2026, 22:47
_AK_
Permanent error when downloading aquasuite.
mardi 29 novembre 2016, 16:34
Hello!
I have a problem. :(
I can not download a new aquasuite 2016-5 or 2017-1. Loading not even begun.
Download the installer from the official website, but when you click on the install button, all the time there is an error - download failed.
It is already tired. Where can I get regular installation files?
Dundys
mardi 29 novembre 2016, 16:56
Do you have antivirus or software/hardware firewall blocking your d/l I have just tried and its all working fine
mardi 29 novembre 2016, 17:08
Was my first idea too. Hundreds of customers have already downloaded and installed the aquasuite software so I am pretty sure the problem that you have must be a problem with your PC.
_AK_
mardi 29 novembre 2016, 17:13
Yes, I agree the problem I have on the PC. But I have already cut off completely antivirus and firewall.
But the problem persists. I can not understand the reason. Therefore, I ask the installation files.
mardi 29 novembre 2016, 17:21
You need an connection without any proxy servers. Mayby an issue with you internet connection or you provider.
They are no man in the middle SSL-Proxy-Servers are allowed.
Dundys
mardi 29 novembre 2016, 17:23
Try instead of disabling your security programs adding the d/l and url to exclusions.
Sometimes by just disabling them, their self defense feature and their service still running in the background and that will stop your downloads without you realizing it.
Sorry if that won't work
Ce message a été modifié 1 fois. Dernière modification effectuée par "Dundys" (29 novembre 2016, 17:24)
_AK_
mardi 29 novembre 2016, 17:31
I ran the loader on a laptop, which is on the same network with my computer. Everything is in order. The problem is I do on a PC. But I can not figure out its cause
_AK_
mardi 29 novembre 2016, 17:35
Guys, I understand that the problem is in my computer. Therefore, I request the installation files aquasuite 2017 to install a program without going through the boot loader
Dundys
It would be nice if we could d/l aquasuite offline installer and do the installation offline if desire, then activate/validate afterwards.
I have few software that are very expensive that also requires online activation, but the download and initial installation can be done either way, why not having something similar with aquasuite.
Ce message a été modifié 3 fois. Dernière modification effectuée par "Dundys" (29 novembre 2016, 17:38)
_AK_
mardi 29 novembre 2016, 17:41
Yes, I just ask the installer offline.
mardi 29 novembre 2016, 17:49
when the setup is not working on your computer you will have the same problem with the aquasuite.
We have no offline installer versions. Only the online installer is available.
_AK_
mardi 29 novembre 2016, 17:55
I worked well aquasuite 2016-3. While I did not remove it before the installation attempt aquasuite 2017-1.
What do I do now?
How to get at least some version of something ?!
Dundys
mardi 29 novembre 2016, 18:00
Did you do the hardware firmware update, if you did ..well that's the downfall, you cant downgrade, if you haven't I have 2016-4 and older offline installers if you want
_AK_
mardi 29 novembre 2016, 18:11
I wrote to you in personal messages.
Or publish please refer to 2016-4 here.
Thank you so much!
Dundys
mardi 29 novembre 2016, 18:28
Let me know if you got it, if not I can upload somewhere else.
Code source
1
http://www.filedropper.com/aquasuitesetup2016-4
Ce message a été modifié 1 fois. Dernière modification effectuée par "Dundys" (29 novembre 2016, 18:38)
_AK_
mardi 29 novembre 2016, 18:44
Now I set the offline version 2016-4.
Everything works fine.
The system is updated properly, I do not use a proxy.
The only problem with the new online loader for new aquasuite.
P.S. Dundys many are not real thank you for your help! And sorry for my bad english
Ce message a été modifié 3 fois. Dernière modification effectuée par "_AK_" (29 novembre 2016, 18:47)
Dundys
mardi 29 novembre 2016, 18:54
I'm glad I was able to help, your English its fine :thumbup:
mercredi 30 novembre 2016, 07:29
today (later) we release a bugfixed version of aquasuite 2016/2017. The the downloader has currently a short timeout for request the data. When you dont have a responsive internet connection you can run in this error.
In the next downloader version we increase the timeouts. Maybe this fix your issues.
_AK_
mercredi 30 novembre 2016, 07:46
OK, thank you for the information. Hopefully the new version will fix the problem.
P.S. Today, I was still trying to dig windows'10 settings. He came to the conclusion that the problem is probably with the creation of temporary files.
Because the request to "aquacomputer.de:443" runs normally. But there is not any file folder. It seems as if the program does not have permission to write to this folder. Change the path for the temporary files are stored in the settings windows 10 does not change anything.
That's my guess, maybe I'm wrong ...
mercredi 30 novembre 2016, 07:54
The installer starts with administator rights. The installer gets from the system the default temp file folder. In normal conditions every user and program has access to this folder.
When the download progress starts (progress bar) and finished downloading it is a problem with your path, otherwise with the internet connection.
Discussions similaires
