• 22.11.2026, 22:52
Looking for a Hydraulic Engineer
mardi 20 décembre 2016, 22:11
I have a 3-port valve I would like to implement for flushing purposes, but I need some feedback from knowledgeable folks.
The 1/4" valve I am looking at has a Cv (Coefficient of Flow) of 0.75.
Is this sufficient for a typical cooling loop?
There is a 3/8" valve available that has a Cv of 1.5, but it is larger and would be more complicated to place.
AE5probigNGslave
mardi 20 décembre 2016, 22:33
Hello,
I think that more important is DN (diameter nominal). 1/4" valves has DN=6 mm, 3/8" valves has DN=10 mm. I use valves for VC with 1/4" with DN=10 mm but standard 2-way.
I work in high pressure cleaners.
BR
George
mercredi 21 décembre 2016, 00:46
Thanks George.
The 1/4" valve I am looking at has a stated "orifice" size of 4,8mm.
I assume the stated orifice is the diameter of the ball bore, and being the smallest constriction in the valve, correlates to the DN.
The 3/8" valve has a stated orifice of 7,1mm.
I suppose either valve will work, but the 3/8" will experience a lesser pressure drop.
I am a bit leery of the 1/4" valve's 4,8mm DN.
H-800.pdf
AE5probigNGslave
mercredi 21 décembre 2016, 23:09
Hello to Texas,
I look over the internet and you need full port ball valve.
Like this: http://www.valworx.com/product/3-way-lea…ull-port-14-npt
Orifice is 9,906 mm. :)
George
Discussions similaires
