• 07.10.2026, 11:19
XenoMorpH
Aquabus / RPM signal cable 3 pins problems
mardi 27 décembre 2016, 23:22
I created my own Aquabus / RPM signal cable. Used 2 old 3 pin female cables and soldered them togheter and sleeved them. Made 2 of them, but they don't seem to work?
Does anyone has an idea why they are not working? I reconnected the standard (pretty long) cables and the devices work with my Aquaero.... But not with those 2 hand-made cables :(
RE: Aquabus / RPM signal cable 3 pins problems
mercredi 28 décembre 2016, 13:51
My initial thought is an open, or you crossed the wires... can't be much else.
Curious, what are you connecting to the RPM signal port?
XenoMorpH
mercredi 28 décembre 2016, 16:11
This is how I created them:
After soldering them I used some heatshrink to protect the solder-joint
Then I single sleeved the cables.
I have no idea why it's not working.....
They are not for the RPM port, fior the aquabus-port...
Ce message a été modifié 1 fois. Dernière modification effectuée par "XenoMorpH" (28 décembre 2016, 16:13)
GTXJackBauer
mercredi 28 décembre 2016, 22:36
What device were you using to connect them too since some devices need a 4-pin for power.
mercredi 28 décembre 2016, 23:11
Did you megger the cable with an ohm meter after sleeving to confirm continuity between the two plugs?
jeudi 29 décembre 2016, 07:12
your cables are reversed! Compare the pin numbers on each side of the cable.
XenoMorpH
jeudi 29 décembre 2016, 11:42
Using a PowerAdjust 2 Ultra and a Farbwerk. They work with the standard 3pin cables....
No I didn't, maybe that's what I could do.....
:S I think you are right :pinch:
Looking at this:
I now see that black and yellow are reversed. :whistling: Stupid me!
I'll try it out this evening Tnx!! :D
XenoMorpH
jeudi 29 décembre 2016, 22:24
And it worked!! But now my Farbwerk is not connecting anymore. Not even with the original cables. :thumbdown: ... I Updated and Rebooted through USB, restarted the pc and reconntec it, but a no go ;(
XenoMorpH
dimanche 8 janvier 2017, 14:17
Having a new problem...can not get any device work on the aquabus anymore. Not even with the standard cables.
I have 2 PowerAdjust 2 Ultra's, reset them to factory defaults, gave them a aquabus number (51 and 52).
Also the Farbwerk had a reset and gave it number (21).
The Aquaero had a factory reset, reconnected the devices one by one to the Aquaero, but they don't get detected. What's going on? :wacko:
XenoMorpH
mardi 10 janvier 2017, 22:42
No one? ;(
mardi 10 janvier 2017, 23:33
Your best bet may be to shoot tech support a message at support@aqua-computer.de
Discussions similaires
