• 29.11.2026, 04:47
Juk
Aquaero 6 full configuration on dual loop
lundi 13 février 2017, 21:54
Hi!
I've been planning my next build, and I'd like to start using the aquaero ecosystem. I have made a diagram showing my plan, but I am not sure if I understood it correctly, and if it will work this way. Here it goes:
Is this OK ?( ?
Thank you!!
Railgun
mardi 14 février 2017, 11:16
Looks good provided the total number of fans chosen don't draw more than each individual channel provides.
Juk
mercredi 15 février 2017, 22:54
Yes, I will be using some NB eloop B14-3, and watts won't be a problem at all :)
The main thing that I am not so sure is the aquabus split. I read the manual and set the bus id according to a table that lists them, but I fear that so many devices may not work correctly.
Thank you!
GTXJackBauer
mercredi 15 février 2017, 23:39
You're only limited to 4 MPS devices. Just look up what is considered a MPS device.
If you should run into issues getting all the devices online via Aquabus, you could always use them in USB, that's if they allow that connection.
