• 30.11.2026, 15:11
Legolas84
Aquaero 6 Pro and Relay... clarifications....
jeudi 16 février 2017, 12:42
hi,
I mounted the relay on my Aquaero 6 pro for the emergency shutdown of the computer.
In aquasuite 2017 - 1.3 at "Allarm Acations" there is the "emergency shutdown" voice, and the actions we have these options concerning the relay:
- Relay ON
- Relay OFF
- Relay Switch for 2 sec
- Relay Switch for 10 sec
What option should I choose to turn off the computer without automatically switches on again?
Thanks...
PS
In "Outputs"page there is "Relay" voice. The options are "Switch off below xx%" and "Switch on above xx%". The current reading is 0%. What does it mean?
Legolas84
dimanche 19 février 2017, 14:39
UP :(
dimanche 19 février 2017, 19:48
On my main board are <4 sec soft-off >4 sec hard-off
so i would say Switch for 2 sec for soft-off or Switch for 10 sec for hard-off if you have the relay on the Power-switch
Ce message a été modifié 1 fois. Dernière modification effectuée par "EnigmaG" (19 février 2017, 19:51)
Legolas84
lundi 20 février 2017, 19:23
ok thanks ;) I set Switch for 10 sec, so my computer should turn off without restart itself ... :)
