• 06.10.2026, 02:52
mychar
Problems with aquaero 6 pro FAN port No.3
lundi 27 mars 2017, 08:11
yestday,my aquaero 6 pro have some problem with FAN port No.3.
the alarm is "overcurrent,fan output deactivated",whats happend?
i don't know how to solve the problem.
GTXJackBauer
lundi 27 mars 2017, 12:32
Give us a bit more details.
1. What model fan is this and how many?
2. What are the specs of said fan(s) and are you with in the controllers limits?
RE: Problems with aquaero 6 pro FAN port No.3
lundi 27 mars 2017, 13:08
It looks like the current draw on your Fan Port 3 exceeded the working limit.
From the Aquaero Manual:
aquaero 6:
Maximum current is 2.5 A per output independent of output voltage, resulting
in a maximum power of 30 W at 12 V. Outputs will be switched of if
amplifier temperatures reach a critical level and will automatically be reactivated
when cooled down. If an output current of 3 A is exceeded, the output
will be permanently disabled. To reactivate the output, the aquaero (or
the complete PC) has to be disconnected from power for a short period of
time. The fan outputs are short-circuit proof.
All fan connectors can be used for conventional fans or PWM controlled
fans. For PWM fans, select “Outputs” → “Fans” → “Fan 1-4” from the menu
and set “Control mode” to “PWM controlled”.
mychar
lundi 27 mars 2017, 13:13
only one,its noctua NF-S12A.controllers limits is 80% - 100%
mychar
RE: RE: Problems with aquaero 6 pro FAN port No.3
lundi 27 mars 2017, 13:17
aquaero 6:
and set “Control mode” to “PWM controlled”.《《《I tried all the mode .but Cannot start again。
lundi 27 mars 2017, 16:43
That Noctua fan lists a max current draw of 0,12 amps, which should allow for about 20 of them on the one port.
Did you disconnect the power supply for a "short period of time" to allow the aquaero to reset, as suggested in the manual?
If yes, your best result will come from contacting aquacomputer support direct at support@aqua-computer.de
