• 13.11.2026, 15:39
HunterVee
Dr. Delid with Haswell
samedi 1 avril 2017, 17:09
Heya Aquacomputer,
Got a simple question, will Dr. Delid which is advertised to delid Skylake and Kabylake, be good for delidding a Haswell processor as well? has anyone tried it before on a 4790k?
Thanks in advance for feedback :D
dimanche 2 avril 2017, 07:43
you have to remove the indexing plastic pins at the Delrin part with a sharp knife. Then it will work.
HunterVee
dimanche 2 avril 2017, 12:49
Hi Stephan,
Thanks for the answer, is there some picture that shows said plastic pins? you mean on the Dr. Delid itself no?
vendredi 7 avril 2017, 15:25
Yes. At the pocket in the Delrin part that covers the CPU are two pins that you have to remove.
vendredi 7 avril 2017, 17:03
