• 06.10.2026, 11:59
dxb750
Aquasuite 2017 wont download !
dimanche 28 mai 2017, 22:00
hi,
Windows 8.1 & clean install of it..
My system Time/Date is correct..
Firewall : OFF
Is there any solution to this problem ? "Download failed, please try again later." ?(
Thanks...
dxb750 a envoyé l’image suivante :
lundi 29 mai 2017, 00:07
I think the server was down, try again.
dxb750
lundi 29 mai 2017, 12:47
Finally the software was downloaded, now everything is well .... thank you
lundi 29 mai 2017, 13:39
@aquacomputer: I believe this is important enough that aquacomputer have a 2nd/mirror server the download software can go to if the primary server is fail.
zetta
vendredi 2 juin 2017, 09:31
I have been trying to download aquasuite for the past 3 days and I get the same error, is it the server or a different problem?
vendredi 2 juin 2017, 14:56
The server is running fine and the setup is working.
zetta
vendredi 2 juin 2017, 15:39
Then any solution to my problem? I have my PC's time set correctly for my timezone and I'm still getting that error. I don't need any new features I just want an old version that would work for basic fan controlling and for some reason I'm forced to use this new launcher thing?
Any downloads for previous versions would be nice too.
vendredi 2 juin 2017, 17:26
make a few screenshots to understand the problem.
zetta
vendredi 2 juin 2017, 21:11
Same problem as OP, I get this error on both this version and when selecting the 2017-2 version
mardi 6 juin 2017, 06:34
I think this is a issue with your system. The software is verifing the HTTPS connection and when check the feedback from the download server.
Try it from a other computer with the same internet connection.
