• 12.10.2026, 04:54
k2mit
D5 USB shows 100% power at 2800 RPM and 0.00 Amps
samedi 8 juillet 2017, 09:42
I have the AC D5 Aquabus/USB connected using both connections while configuration (maybe that is part of the problem).
The Aquasuite shows the pump under Aquareo but the maximum RPM gives 2880 RPMs and shows 0.00 amps. I thought max RPM on these was 4,500.
What am I doing wrong?
Jakusonfire
mercredi 12 juillet 2017, 16:37
You need to have the pumps maximum power set to 100% in the pump tab of the Aquaero menu, plus you need whatever controller you have the pump assigned to set to 100%
If you just have max set to 100% in the pump tab, that is just the max it can go to. The controller tab needs to be at 100% to actually make it run at full speed.
If the controller tab is at 100% but the pump tab max is set low then even if the controller is at 100% the pump can't run higher than its max speed setting. It just runs at 100% of its min and max speed settings, or 50% of its max speed setting etc.
To get the pump at full speed you can just set it to 'Maximum power' on the pump tab instead of 'set by controller' or Manual Preset'
Ce message a été modifié 1 fois. Dernière modification effectuée par "Jakusonfire" (12 juillet 2017, 16:39)
