• 21.11.2026, 16:44
GAqua
Bug: After Update, Flow Sensor connected on Fan 1 of Aquaero 6 no longer works
dimanche 12 novembre 2017, 02:31
I have an Aquaero 6. I just updated to Aquasuite 2017-3.1.
I backed up my settings and updated the Aquaero firmware after the software update. I loaded the previous settings back.
Now the flow sensor that was attached to fan1 is no longer working. It thinks its a fan again.
dimanche 12 novembre 2017, 03:27
The flow sensor have to be connected to the "aquabus low" port now.
Ce message a été modifié 1 fois. Dernière modification effectuée par "wpuser" (2 décembre 2017, 19:57)
GAqua
dimanche 12 novembre 2017, 06:31
Thanks, i'll check that out.
GAqua
vendredi 1 décembre 2017, 20:10
The flow sensor have to be connected to to "aquabus low" port now.
This indeed works.
While the notes say that you can still use the Fan-1 port for a flow sensor, this is NOT true. If you only have 2 flow sensors, they have to go to the FLOW port and the AQUABUS LOW ports first.
GTXJackBauer
samedi 2 décembre 2017, 03:03
This indeed works.
That's correct.
