• 13.11.2026, 13:22
jacenty
Aquaero LT 6 problem. Windows 10 - Solved.
mercredi 29 novembre 2017, 21:17
Hello!
I have a problem with Aquaero LT 6. When I try to connect Aquaero via USB I get a blue screen and "Bad Pool Header" message. Before this I see message "Configuring a new hardware" or something like that. I have Windows 10, mainboard Asus Maximus VIII Gene.
Ce message a été modifié 1 fois. Dernière modification effectuée par "jacenty" (1 décembre 2017, 22:43)
mercredi 29 novembre 2017, 21:37
i think your windows or ar part of your system drivers is broken.
you have to repair your windows.
Try update all drivers, check your bios.
Do not overclock hardware.
CHeck the device with an other computer.
jacenty
mercredi 29 novembre 2017, 21:46
Oh I see! I overclocked my CPU. Do you thing this is a problem? I'll try to reinstall system. Thanks for the reply. ;)
GTXJackBauer
jeudi 30 novembre 2017, 05:06
Could be a bad CPU OC. I would follow what Sebastian said and run everything updated and repaired if it needs to be and all on stock settings.
jacenty
jeudi 30 novembre 2017, 19:47
Should I worry about it? I don't know, what the red light means. I have connected four fans and a temperature sensor. Aquaero works, of course, but I still can't connect aquaero via usb
Ce message a été modifié 3 fois. Dernière modification effectuée par "jacenty" (30 novembre 2017, 19:56)
jacenty
vendredi 1 décembre 2017, 22:14
Ok, everything is ok. I did what Sebastian said. I mean repair Windows and upgrade drivers mainboard, and now Aquaero works astonishing well. :)
Thanks for reply.
Ce message a été modifié 1 fois. Dernière modification effectuée par "jacenty" (1 décembre 2017, 22:19)
GTXJackBauer
samedi 2 décembre 2017, 03:04
Thanks for reply.
Glad it all worked out. :thumbsup:
