• 25.11.2026, 20:39
ProRules
Where do i connect kryos next vision cable?
samedi 16 décembre 2017, 23:26
Hey, i have cuplex kryos next with vision.
There is a cable that comes out of the cpu block.
Where do i connect it to on the motherboard?
zarrkon
dimanche 25 février 2018, 21:11
To your USB 2.0 header on you Mobo. Make sure your orientation is correct.
Revan654
RE: Where do i connect kryos next vision cable?
lundi 26 février 2018, 21:11
It's a five pin USB 2.0 cable, It can be connected to any of your USB 2.0 headers. It has to be connected with following wire colors BB--R. You can also use the Hubby7 if you need more USB 2.0 slots. You can also connect aquabus cable if you want as well.
