• 02.10.2026, 18:56
darkinners
High Flow usb screw thread size?
mardi 20 février 2018, 14:03
I have the High Flow USB sensor, I planning to mount at the bottom of the computer case, I see there are 4 screw hold under the sensor.
Do you guys know what are the thread size of those holes? and how deep? Thanks!
mardi 20 février 2018, 15:35
In the web shop description for the usb high flow sensor, it states under technical details:
"Mounting threads: 4x M3, rectangularly arranged at intervals 35 x 44 mm"
As to the depth, open up a paperclip and insert one end into the screw hole.
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (20 février 2018, 15:38)
darkinners
mercredi 21 février 2018, 04:53
Thanks man!
