• 29.11.2026, 04:28
knacker
Farbwerk questions
mercredi 4 avril 2018, 19:18
Hi- anyone let me know what connection the farbwerk need for rgb strips as cant remeber the model needed
Also, is it possible to connect Phanteks Glacier CPU & GPU block to the farbwerk? If so, what would I need- the rbg extension with the block stats the connections as 12v, g,r,b - would this work if connected to the farbwerk as it would be very good if it could 8)
Thx
Ce message a été modifié 1 fois. Dernière modification effectuée par "knacker" (4 avril 2018, 20:39)
knacker
jeudi 5 avril 2018, 13:10
Anyone have any ideas?
jeudi 5 avril 2018, 14:56
Pin assignment of farbwerk is
Pin 1: +12 V
Pin 2: GND blue
Pin 3: GND red
Pin 3: GND green
knacker
jeudi 5 avril 2018, 15:44
thanks- looks like the Phanteks rgb cable will allow this to work so I'll give it a try
