• 13.10.2026, 20:51
Gene46
Aquacomputer D5 pump not being detected by Aquaero 6 and Aquasuite after firmware update
dimanche 8 avril 2018, 18:30
Hello, I've searched the forums but have not managed to find a satisfactory answer. i recently replaced my mobo (MSI Godlike Gaming Carbon) and had to reinstall windows. I downloaded the latest version of aquasuite and it told me to update my aquaero 6 to the latest version. Now i can't detect my two AC D5 pumps. They are connected via a pwm splitter to the aquaero 6 high aquabus port. This all worked before but i can't understand why its not detecting the pumps. With the pumps connected they run at 100 percent which cant be good. I have disconnected the pumps, powered down the computer, remove the psu plug, waited a few minutes before plugging in the psu and turning on the computer. I still cannot see the d5 pumps in aqausuite. Would appreciate any advice, as i'm afraid to run the pumps at 100 percent the whole time. Thanks.
Bartdude
lundi 9 avril 2018, 08:32
First time setup needs to be connected via USB, after that you should be fine
Gene46
lundi 9 avril 2018, 14:25
Thank you for your reply bartdude. Bearing in mind I have a aquaero 6 can you please explain whats a fool proof step by step way of doing this? I have two d5 pumps. Do I connect them one by one to the mobo and boot up? As I mentioned previously both are running via pwm splitter to aquaero 6 high aquabus port. Just connect directly to mobo and boot up? Or does the aquaero need to be installed in the aqausuite as well? I’m a complete noob at this so thank you for your patience.
Thank you.
EDIT: Managed to fix this thanks. I have another question about temp sensor but will start a new thread on it after searching thanks!
Ce message a été modifié 1 fois. Dernière modification effectuée par "Gene46" (9 avril 2018, 15:57)
