• 22.11.2026, 22:25
belia
aquasteam XT on/off
samedi 14 avril 2018, 12:30
Hello,
I looking for a option,
i want to shup down my aquasteam when i don't play video games or when the temperature is under 40degres for exemple.
I don't find is, i think is option is not incluse...?
thx for readind me
Sorry i have a bad english^^
Fieldrider
samedi 14 avril 2018, 18:31
In my opinion it's not a good idea to stop the Waterflow when the PC is on. Even when the components are in idle. They still produce some heat.
belia
samedi 14 avril 2018, 19:09
My watercolling is just for my GPU (graphic card). It's for that i want to shut down my pump when i don't play.
Dundys
samedi 14 avril 2018, 19:28
Like stated above, even if you wont play your game and your system is on idle your GPU(s) are still active and produce ton of heat and before your know it your block(s) will get extreme hot and them you facing problems. Water needs to circulate your loop, even if its very slow, but it has to take the heat away from the hot spot area
Ce message a été modifié 1 fois. Dernière modification effectuée par "Dundys" (14 avril 2018, 19:29)
