• 01.10.2026, 22:41
Kayvan
Extension cable for Aquaero 6 display?
lundi 3 septembre 2018, 23:02
I've been looking for a 24 pin 0.5mm pitch ribbon cable with headers to connect the display to the main board of the Aquaero.
I have searched google for days and can not find anything even close. All the cables I have found are 1mm pitch.
Even individual jumper cables are 1mm.
Does anybody know where to get this?
I am trying to place the display in a different location than the main unit.
mardi 4 septembre 2018, 01:58
What length of cable are you looking for?
The Gigant series external radiators have the display mounted separate from the aquaero with a cable about 20 cm long.
If 20 cm is sufficient, it should be a stock item you can purchase from aquacomputer.
If you need longer, you may be able to negotiate a custom order (if length is not limited).
support@aqua-computer.de
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (4 septembre 2018, 02:00)
Kayvan
mardi 11 septembre 2018, 16:02
Thanks! Just ordered one via email address provided.
Citroene
samedi 6 février 2021, 22:03
Is it possible to buy the extension cable?
because i send an email 1 week ago and didn't get an answer
dimanche 7 février 2021, 01:19
Look here:
Please note:
Due to a high volume of inquiries, it currently takes up to two weeks to respond to e-mails.
dimanche 7 février 2021, 01:23
Since the gigant radiators are still listed in aquacomputer's webshop, I believe you can still purchase the cable.
But on their support page they have the following statement:
Please note:
Edit: lol, ninja'd
Ce message a été modifié 3 fois. Dernière modification effectuée par "InfoSeeker" (7 février 2021, 01:26)
