• 22.11.2026, 22:08
knacker
Aquaero 6XT- can it be used without the screen attached
mardi 16 octobre 2018, 15:01
Can I use an AE6 XT without the attached screen via software as I would like to use it in a new Evolve X build but can only fit it in without the screen unit
Thx
Shoggy NEXT
mardi 16 octobre 2018, 16:59
When you remove the display it automatically becomes a LT variant. In other words this is no problem.
If this device was not used with the aquasuite before: make sure that the first time you use this aquaero with the aquasuite setup or aquasuite software is with the display in place because otherwise you will only get a license for two major versions instead of three major versions.
knacker
mardi 16 octobre 2018, 17:25
thanks Shoggy- I have been using it with aquauite for a number of months but a move to a different case means I dont have a 5.25 bay in it so trying to fit a quart in a pint pot!
Still need to see if the Phanteks rgb work with the farbwerk so thats another question!!!!
