• 10.10.2026, 04:25
knacker
Aquacomputer D5 USB/Aquabus pump to motherboard
vendredi 19 octobre 2018, 12:52
Is there a way for me to connect the above to my motherboard to control pump without using my AE6 as I cant fit it in the case anywhere
I am really regretting getting this new case at the minute or can I still use the aquauite without the AE6 being connected?
Ce message a été modifié 1 fois. Dernière modification effectuée par "knacker" (19 octobre 2018, 13:08)
Shoggy NEXT
vendredi 19 octobre 2018, 13:34
Yes, of course. The connection to the aquaero is only an option.
You can connect the pump directly to an internal USB header of your mainboard.
knacker
vendredi 19 octobre 2018, 14:07
Do you mean I can use the Aquasuite without the AE6 being connected? If so that will give me a little bit of extra room as I am having to crowbar it in :S
Hufeisen
vendredi 19 octobre 2018, 17:06
Yes.
knacker
vendredi 19 octobre 2018, 20:44
Thanks for that
Jakusonfire
lundi 22 octobre 2018, 11:20
The only difference is that you will only have manual style, fixed speed controls through aquasuite instead of being able to add the pump to an automatic controller that the Aquaero uses aquabus for, or control the pump through the Aquaero of course.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Jakusonfire" (22 octobre 2018, 11:22)
Discussions similaires
