• 07.10.2026, 21:22
kn5
QUADRO (USB) not detected with 6XT by Aquasuite (HUBBY7)
mardi 30 octobre 2018, 22:14
Hello,
I have Aquaero 6XT, D5 pump (auquabus) and usb hub from AquaComputer and now I bought QUADRO.
Unfortunately, after connecting it via USB, aquasuite (newest version) can not see it. After connecting QUADRO via aquabus, aquasuite sees additional channels of fans and temperature sensors.
However, I need QUADRO as a separate controller (via usb) to have additional channels controlled in CURVE mode
I disconnect 6XT, reinstall aquasuite, the installer detects QUADRO, but the QUADRO tab still does not appear in aquasuite
I connected QUADRO to another computer, without aquaero software. QUADRO was recognized by the installer and the QUADRO tab appeared in aquasiute
I was able to update the firmware and operate
I returned to my computer, unfortunately without any changes.
I have a question if I have to manually change something in the registry or some configuration file?
Thank you in advance for your help
Ce message a été modifié 1 fois. Dernière modification effectuée par "kn5" (10 février 2019, 17:03)
GTXJackBauer
RE: QUADRO (USB) not detected with 6XT by Aquasuite
mercredi 31 octobre 2018, 04:37
Hello,
You'll need to connect the QUADRO via USB and update it's firmware. Shutdown and unplug for a few mins. Power back on and it should be either and you can have both USB and Aquabus installed on any of those devices making it easier to choose from through the software instead of manually doing it every time.
kn5
mercredi 31 octobre 2018, 18:39
Ok, I already update firmware on different machine. Now I unplug QUADRO and try tommorow to connect to my computer.
Thank You.
Edit:
Today I connect QUADRO to my PC and OS detect it but Aquasiute not..
kn5 a envoyé les fichiers suivant :
  • quadro USB.JPG (18,19 kB - téléchargé 1 184 fois - Dernier téléchargement : 5 octobre 2026, 13:01)
  • aquaero.JPG (71,16 kB - téléchargé 1 191 fois - Dernier téléchargement : 2 octobre 2026, 07:01)
Ce message a été modifié 1 fois. Dernière modification effectuée par "kn5" (2 novembre 2018, 18:04)
kn5
dimanche 10 février 2019, 15:40
So a small update. I installed the new w10 system.
Quaddro is still not detected as a USB device in Aquasiute. Only as Aquabus device. If no Aquabus conection, then no Quadro device in Aquasiute detected.
Factory reset also did not help.
Any suggestions on how to activate the Quadro tab in Aquasuite?
Thanks
kn5
dimanche 10 février 2019, 17:02
So, if I connect Quadro directly to MB Asus Crosshair VI Hero (internal connector, there are only two!) Quadro is recognized by Aquasiute :)
If I connect via HUBBY7 (53230) then, it is not detected by Aquasuite, but Windows detects the device.
Other devices like D5 and USB ports on the front work fine with HUBBY7.
Unfortunately, I need more than two USB ports. (Aquaero, D5, Quadro, USB x4 ...)
Aquaero also not working witt HUBBY7
Is HUBBY7 damaged or is it incompatible?
Thanks
Bartdude
mardi 12 février 2019, 12:54
Yet another AMD MB that doesn't play well with Hubby7, take a look at this thread....Here
Ce message a été modifié 1 fois. Dernière modification effectuée par "Bartdude" (12 février 2019, 12:55)
