• 22.11.2026, 21:00
Silky_
Aquacomputer Pressure sensor accessories!
lundi 24 décembre 2018, 01:56
I have recently purchased an Aquacomputer Pressure Sensor Delta 1000 as knowing the pressure level of my loop will be interesting.
However, where can I purchase the accessories needed in the U.S. as the Aquacomputer site will have to charge me about $40 US dollars for shipping alone. Any guidance will be greatly appreciated. Thank you :(
Update: I did see that they have a standard postage option thats only $8 but may take up to 30 days. If that is my only option then I'll have to do it.
Ce message a été modifié 1 fois. Dernière modification effectuée par "Silky_" (24 décembre 2018, 01:59)
lundi 24 décembre 2018, 04:42
Silky_
lundi 24 décembre 2018, 18:26
Sad to say none of those sellers carry the equipment needed, It will have to be purchased through the Aquacomputer store.
Even Aquatuning doesnt have the hardware, I'll order it from Aquacomputer and just wait for the shipping. Thanks. :thumbdown: :thumbdown: :thumbdown: :thumbdown: :thumbdown: :thumbdown: :thumbdown:
lundi 24 décembre 2018, 19:25
Not sure if you are wanting to determine the pressure of the loop or the fluid level in the reservoir, but the 1000 cm (10 meter) water column unit you selected is probably well outside the range of usefulness for a typical cooling loop. The 40 cm or 100 cm, max, units may better serve your needs. Just thought I would mention this before you built the unit in.
Silky_
mardi 25 décembre 2018, 02:21
Understood however as mentioned just of interest to utilize the Aquaero to its full, and I have a small LCD in my case that has the my Aquasuite overview page.
