• 22.11.2026, 23:11
Hyeonwoo_H
Ask how to set up the Virtual Flows Sensor for D5 Next Pump.
mardi 25 décembre 2018, 15:32
Hello~
I received 'D5 Next' pump on Christmas Eve to Ttorysystems in Korea.
By the way, Virtual Flow Sensor does not work, do I need additional configuration?
I tried the calibration several times by shutting off the ball valve as described, but it still does not change at 0L / h.
I've tested the pump speeds varying, but the results are the same. :wacko:
I tried blocking with a ball valve on an aqua filter. Should I block the outlet directly?
Please~ Help..... ;(
My system is structured like this. "HeatKiller D5 Combo Reservoir + D5 Next Pump" -> "360 Radiator" -> "CPU Block" -> "360 Radiator" -> "GPU Block" -> "Aqua Computer Filter" -> "Reservior"
Firmware 1003.
Ce message a été modifié 2 fois. Dernière modification effectuée par "Hyeonwoo_H" (25 décembre 2018, 18:24)
mercredi 26 décembre 2018, 13:59
You need at least a flow of 80 liters per hour and you need the right coolant (one of these: Click)
Hyeonwoo_H
mercredi 26 décembre 2018, 14:54
I changed the pump from the loop that was already built and removed the flowmeter and the thermometer that were already installed.
I used the D5 40% PWM setting in the existing configuration.
At this time, the flow rate is 2.76L / m, which is calculated 165L / h, so i think about the flow rate seems to be no problem..
Should I preserve the pressure in the loop when I shut off the loop?
I open the lid of the water bottle once to remove the air bubble.
