• 01.10.2026, 11:12
Nrg91
D5 Next Flow Sensor
mardi 12 février 2019, 15:41
Hi everyone
I have a Aquacomputer D5 Next, I can not make the flow sensor work properly
Setting the pump to 100%, tells me that the flow is too low, while setting it to 90% can calculate an estimate, although I think it is low 120l / h
With the Koolance flowmeter I had before, the flow was around 200l / h
I did the calibration as instructed, and I am using the Double Protect Ultra Aquacomputer as liquid
hossam.sy
mardi 12 février 2019, 20:48
200l/h for a D5 seems exaggerated, using Aqua-computer high flow sensor was getting 115-125 l/h, so the number you posted seems legit, not the Koolance one, i won't trust the koolance sensor though, let's see if someone else have something different to say here...
Nrg91
mardi 12 février 2019, 20:55
Sorry I forgot to say my loop:
1x Alphacool XT 45 360mm
1x Xspc Rx V3 240mm
1x Ekwb Supremacy Evo
1x Ekwb Rx Vega 64
3x 90 degrees fittings
4x 45 degrees fittings
2x normal fittings
1x D5 Next
The Koolance flowmeter measured 3.7 L / m, while the D5 Next flowmeter measures 100-110 L / h
Making a calculation is as if the Aquacomputer flowmeter scored 1.83 L / m
I specify that I am talking about the virtual flowmeter of the D5 Next
Ce message a été modifié 11 fois. Dernière modification effectuée par "Nrg91" (12 février 2019, 21:16)
