• 18.11.2026, 16:13
Syberon
Audio analyzer not working
samedi 20 avril 2019, 12:08
I trying to setup RGBpx port on my QUADRO to work with audio analyzing function but with no luck.
At first i enabled "audio and video" in Aquasuite 2018-11. After this if i choose a "windows default audio device" service "AquaComputerServiceHelper.exe" immediately crashes with following error:
"CSCore.CoreAudioAPI.CoreAudioAPIException
в CSCore.SoundIn.WasapiCapture.InitializeInternal()
в CSCore.SoundIn.WasapiCapture.Initialize()
в AquaComputer.Media.AudioData.xqWotiReAQeuuTpVKBa(System.Object)
в AquaComputer.Media.AudioData.YD4JAqXdsI()
в AquaComputer.Media.AudioData.Enable()
в AquaComputer.ServiceHelper.ServiceHelperMain.fgCHWYfTZdDAh7SiuV7(System.Object)
в AquaComputer.ServiceHelper.ServiceHelperMain.M4jv6bBlKD()
в System.Threading.ExecutionContext.RunInternal(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
в System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object, Boolean)
в System.Threading.ExecutionContext.Run(System.Threading.ExecutionContext, System.Threading.ContextCallback, System.Object)
в System.Threading.ThreadHelper.ThreadStart()
I found that there are another user on this forum reported about the same error, but no response followed.
If i choose another device "Speakers (Sound Blaster Z)" from this list that is my default sound output device then "AquaComputerServiceHelper.exe" successfully starts but it always gets 100% level on every channel in Aquasuite.
I have another options in device select list in Aquasuite 2018 but changing it not helps.
How to get this function to work?
mardi 23 avril 2019, 07:36
This happens when you not using the windows default driver. Som sound driver software make som strange things with virtual sound devices and a corrupt channel mapping.
Try the windows driver. try to close all 3rd party sound software.
We are working to fix this problem.
