• 11.11.2026, 13:57
DaveT
Thermistor compatibility
lundi 24 juin 2019, 17:54
What are the specs of Aquaero supported thermistors (R and B values)? I want to use flow meter + temperature sensor combo unit from Koolance and I know that it uses R25=10kΩ B25/85=3435K NTC thermistor. Can it be used with Aquaero as-is or Aquaero expects different R and B values?
DaveT
mardi 25 juin 2019, 10:39
Follow up question: what exactly is Calitemp? Is it thermistor, thermocouple or some temperature-sensing IC?
mardi 25 juin 2019, 15:24
Calitemp uses a calibrated digital temperature probe that communicates via aquabus. The sensor is part of a integrated circuit.
You can adjust the offset in the aquaero sensor calibration.
