• 12.10.2026, 21:47
Hellvetic
New build with LL120s
mardi 10 septembre 2019, 00:18
Hi everyone,
I am building a new liquid cooled computer computer and I would need some insight from the AquaComputer experts of this forum
I will have 12 Corsair LL120 as well as a Protium D5 Pump a high flow sensor and 4 temp points (3 air, 1 for the loop)
Looking into all the new goodies of AquaComputer I think that the way to go for this setup would be:
3*(4* LL120 —> 1* Splitty4) —> 1* Fabwerk 360 (for the RGB) —> PC (via USB) —> AquaSuite
3*(4* LL120 —> 1* Splitty4) —> 1* Quadro (for the power) —> PC (via USB) —> AquaSuite
4* Temp Sensors —> 1* Quadro
1* Protium D5 —> 1* Quadro
1* Flow Sensor —> 1* Quadro
Would that work?
Or would i need anyway an Aquaero 6 to tie everything into the AquaSuite ?
Thank you in advance for your help :)
Ce message a été modifié 2 fois. Dernière modification effectuée par "Hellvetic" (10 septembre 2019, 00:22)
mardi 10 septembre 2019, 16:21
That could all be controlled by the aquasuite.
The only option I am aware of you loose by not having an aquaero, is virtual sensors.
Ce message a été modifié 2 fois. Dernière modification effectuée par "InfoSeeker" (12 septembre 2019, 01:24)
Hellvetic
mercredi 11 septembre 2019, 13:19
Thank you for your reply InfoSeeker
I thought Quadro still had 8 vSensor readings.
According to the Quadro page:
· Four temperature sensor inputs
· Eight further values can be transferred from the PC to the QUADRO using the aquasuite software
· Flow sensor input
Therefore i assumed it would cover my needs of CPU and GPU temps without the need of an Aquaero 6 as i am cramping up the case quite a bit already
TigerFire13
mercredi 11 septembre 2019, 14:45
Hellvetic,
The Quadro will indeed allow you to use 8 software sensors (cpu temp, etc) shared by Aquasuite software.
Virtual sensors are different. The common example I can think of is calculating the difference between an ambient air temp sensor and a water temp sensor, to produce a delta value, that appears as a single sensor. This is usually a better way to control the radiator fans.
Hellvetic
mercredi 11 septembre 2019, 22:11
Ah haaaaaa!
Thank you very much for the clarification TigerFire13!
I thought it was a given that you could have deltas... i was sure it was just a feature of AquaSuite and therefore not related to the HW
But then, considering it’s a water cooled build (3* 360) it makes sense to have the virtual sensors as it’s the magic sauce to optimise the system...
Therefore i guess the setup would be the same as in the original post but with an aquaero instead of the Quadro (a bit unfortunate as i will have to rethink some wiring)
Thank you a huge lot for your help :)
jeudi 12 septembre 2019, 01:16
If you go with an aquaero 6 LT you can mount it on a bulkhead in the back/basement somewhere, and won't need a 5¼" bay.
Edit: You may need to do some homework regarding the compatibility between the Protium D5 & aquaero PWM specifications.
The aquaero follows the Intel specs strictly, and you may need to implement a minor modification if the pump is not fully Intel PWM compliant.
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (12 septembre 2019, 01:25)
Hellvetic
jeudi 12 septembre 2019, 08:21
Thanks for the tip InfoSeeker!
I assumed that It was per default a fully compliant PWM pump as Singularity Computers use all the time that combination
I won’t have any bays so I am rather forced on the LT
I will have to re-route some tubes then to make space :)
Cheers
