• 29.11.2026, 07:10
squadamPC
[Problem] D5 Next + RGBpx strips not working
dimanche 6 octobre 2019, 13:05
Hello
A month ago I started buying stuff for my new project. D5 + RGBpx strips are a part of it.
yesterday I finally assembled everything but I cant get my RGB strips to work. I checked them with my other D5 Next when I got the and there was no problem.
After starting my system for the 1st time Aquasuite did update firmware on D5s. Now after I choose in aquabus RGBpx LED there is only a quick blink and strips seam dead.
I believe that it might be caused by firmware update.
Just so you now - I am sure that the strips are connected in correct order/direction.
The LEDs on the pump are working fine.
DirtyBear
mardi 15 octobre 2019, 23:52
You have to go to Aquasuite
And at D5 Next pump go to System and click RGBpx LED
Then all your RGB strips should work now
DirtyBear a envoyé l’image suivante :
Discussions similaires
