• 25.11.2026, 22:50
GetSchwiftyClub
Quadro + D5 Next connection
vendredi 6 décembre 2019, 02:12
Is this a possible connection of the Quadro and D5 Next pump?
Quadro (Connected to the MB with USB) -> D5 Next (Connected to the Quadro with Aquabus)
(Quadro Fan Channel 1: 4x fans)(Quadro Fan Channel 2: 4x fans)(Quadro Fan Channel 3: 2x fans)(Quadro Fan Channel 4: 2x fans)
Additional Flow Sensor added to either D5 Next or Quadro. 42 addressable RGB LEDs on RGBpx plug (Heatkiller XS/S/M strips). Will use the Temp Sensor that is internal on D5 Next.
My motherboard only has 1x USB header so I was hoping the Quadro and D5 Next could be connected through Aquabus.
Thank you!
vendredi 6 décembre 2019, 07:14
No, only a USB connaction is possible. You can use the aquabus only with a aquaero 5/6.
RE: Quadro + D5 Next connection
vendredi 6 décembre 2019, 13:47
Have you considered the HUBBY7? It should solve your single USB port problem.
Ce message a été modifié 1 fois. Dernière modification effectuée par "InfoSeeker" (6 décembre 2019, 13:49)
GetSchwiftyClub
vendredi 6 décembre 2019, 22:42
Thank you for the response :) If both the Quadro and D5 Next are connected to a internal USB 2.0 plug they will still both communicate to AquaSuite, correct? And all 4 channels of the Quadro can be controlled independently?
After posting and continuing to evaluate options I did find the option of a 2.0 splitter. There are little 1 into 2 plugs but I think a Hubby7 or the NZXT module would be best as they have PSU power. The NZXT has an extra two USB-A too which would be nice to plug my keyboard and mouse into and save I/O ports for other stuff.
With that option it would still be a very clean minimal setup: (Quadro controlling fans/RGB)(D5 Next pump with Temp/Flow display) I really like the Next since it has the digital readout for Temp/Flow and I don't have to figure out any other displays connected to sensors. I also don't think I'll fully utilize the Aquaero since I really only need the fans controlled and the pump. This may be the perfect setup.
GTXJackBauer
samedi 7 décembre 2019, 05:37
NZXT splitter is fine but they did have some issues with some of them. To be safe incase you get a hold of old stock, I would just get the HUBBY7. They're solid and I bought 2 of them. If I ever need more (quite possible lol), I'm going with the HUBBY7s.
